Had my 2005 300C to the dealer to have its filter changed and it had a minor tranny leak. Pan gasket was changed as well as the filter and fluid.
Service has been done and I went out to pull my car forward and there was a puddle of fluid on the driveway. It is definitely new fluid seeing it is bright red versus the older dark red leaks I had before the change.
I put the car up on ramps and could see that it was leaking at the pan again. Saw accumulation of fluid on the pan bolts as well as some under the pan itself. All the bolts seem to be tight and I could see after 30 minutes that the back drivers bolt area had some fluid seeping.
Is it possible that you can overtighten this pan and cause the gasket to leak or should i just buy a new pan?
Has anyone else had a problem like this?
The connector seal was done 5 years ago under the TSB. Can it start to leak again?
