P0404 and 0406 on a 3.5
27K views 29 replies 17 participants last post by  RunningBull
#1 ·
Got an engine light today so checked for codes and these two popped up..
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0406 Exhaust Gas Recirculation Sensor A Circuit High
Mag is a 2006 3.5 RWD.
Any pointers on what I need to check/fix.
Car was in for an oil change yesterday but everything top side of the engine looks in place.
Thanks in advance.
#2 ·
most likley gonna need the EGR valve...kind of common..many post in the past with members having the same problem
P0406-EGR POSITION SENSOR CIRCUIT HIGH
[/B]
  • When Monitored:
  • With the ignition on and battery voltage greater than 10.4 volts.
  • Set Condition:[/B] The PCM detects that the Exhaust Gas Recirculation Valve input voltage is above the maximum acceptable value.
Possible Causes[/B] INTERMITTENT DTC (F856) 5 VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE (K34) EGR SIGNAL CIRCUIT SHORTED TO VOLTAGE (K34) EGR SIGNAL CIRCUIT SHORTED TO THE (F856) 5 VOLT SUPPLY CIRCUIT (K34) EGR SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE (K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE EXHAUST GAS RECIRCULATION VALVE POWERTRAIN CONTROL MODULE (PCM)
[/B]
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.[/B]
Diagnostic Test
1. DTC IS ACTIVE [/B]
Start the engine and allow it to reach normal operating temperature.
WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts, or fan. Do not wear loose clothing. Failure to follow these instructions can result in personal injury or death.
NOTE: Diagnose and repair any system voltage or sensor supply voltage DTCs before continuing with this test.
With the scan tool, select View DTCs.
Is the status Active for this DTC?
Yes
  • Go to 2
  • Refer to the *CHECKING FOR AN INTERMITTENT DTC Diagnostic Procedure.
2. (F856) 5 VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE [/B]
Turn the ignition off.
Disconnect the Exhaust Gas Recirculation Valve connector.
Disconnect the Powertrain Control Module (PCM) connector.
Turn the ignition on.
Measure the voltage of the (F856) 5 Volt Supply circuit in the Exhaust Gas Recirculation Valve harness connector.
Is there any voltage present?
Yes
  • Repair the (F856) 5 Volt Supply circuit for a short to voltage.
  • Perform the PCM Verification Test.
  • Go to 3
3. (K34) EGR SIGNAL CIRCUIT SHORTED TO VOLTAGE [/B]
Measure the voltage of the (K34) EGR Signal circuit in the Exhaust Gas Recirculation Valve harness connector.
Yes
  • Repair the (K34) EGR Signal circuit for a short to voltage.
  • Go to 4
4. (K34) EGR SIGNAL CIRCUIT SHORTED TO THE (F856) 5 VOLT SUPPLY CIRCUIT [/B]
Measure the resistance between the (K34) EGR Signal circuit and the (F856) 5 Volt Supply in the Exhaust Gas Recirculation Valve harness connector.
Is the resistance below 100 ohms?
Yes
  • Repair the (K34) EGR Signal circuit for a short to the (F856) 5 Volt Supply circuit.
  • Go to 5
5. (K34) EGR SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE [/B]
CAUTION: Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals, resulting in poor terminal to pin connection. Install Miller Special Tool #8815 to perform diagnosis.
Measure the resistance of the (K34) EGR Signal between the Exhaust Gas Recirculation Valve harness connector and the appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
Yes
  • Go to 6
  • Repair the (K34) EGR Signal for an open circuit or high resistance.
6. (K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE [/B]
Measure the resistance of the (K900) Sensor Ground circuit between the Exhaust Gas Recirculation Valve harness connector and the appropriate terminal of special tool #8815.
Yes
  • Go to 7
  • Repair the (K900) Sensor Ground circuit for an open circuit or high resistance.
7. EXHAUST GAS RECIRCULATION VALVE [/B]
Connect the Powertrain Control Module (PCM) connector.
Connect a jumper wire between the (K900) Sensor Ground circuit and the (K34) EGR Signal circuit in the Exhaust Gas Recirculation Valve harness connector.
With the scan tool, read the Exhaust Gas Recirculation Valve signal voltage.
NOTE: The sensor voltage should be approximately 0.0 volts (plus or minus .1 volt) with the jumper wire in place.
Does the scan tool display the voltage as described above?
Yes
  • Replace the Exhaust Gas Recirculation Valve in accordance with the Service Information.
  • Go to 8
8. POWERTRAIN CONTROL MODULE (PCM) [/B]
Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Exhaust Gas Recirculation Valve and the Powertrain Control Module (PCM).
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals.
Monitor the scan tool data relative to this circuit and wiggle test the wiring and connectors.
Look for the data to change or for the DTC to reset during the wiggle test.
Refer to any Technical Service Bulletins that may apply.
Were any problems found?
Yes
  • Repair as necessary.
  • Replace and program the Powertrain Control Module (PCM) in accordance with the Service Information.
#3 ·
CRAP!!! Was afraid of that .. Just thought mighta been something simple due to timing of oil change being the last thing on way home last night and light popped on way to work.
Damn.
#9 ·
In and out done like dinner .. Okay so took a lil over an hour but I had time to look at the other cars on the lots and bought a spring jacket..
EGR all fixed and no more light,.
While I was there I mentioned that my heat controls didn't have any of the lights working. He started to say that bulb replacement couldn't be covered under warranty but I chimed in that I had already looked at replacement bulbs and that they are soldiered in to the pcb.. "Oh in that case we'll replace the whole unit, let me check if we have one in stock"
They did and it's replaced now too ..
Was a really simple in out no issues and great to deal with..
#11 ·
The numbers on my paper work are as follows..
Labour Rate 99.95/hr
Starscan flat - 99.95
Valve- 85.85
Gasket- 3.80
Labour 1.5 - 149.93
Total for EGR if out of pocket.. 339.53 CDN plus 13% tax in Ontario = 383.67
The Heater control not that anyone cares..
Control Unit- 102.00
Labour .3 - 29.99
Total 131.99 CDN plus 13% tax in Ontario = 149.15 CDN
Grand Total that would have been my bill.
532.82 CDN.
I would say that I am happy to have bought the additional warranty.
#14 ·
Valve- 85.85
Gasket- 3.80
Labour 1.5 - 149.93
Labour .3 - 29.99
532.82 CDN.
For us non warranty folks is the Starscan flat part of the repair required?
#12 ·
There must be something in the air! I just got a 0406 DTC today and thought I'd check here for tips - thanks for the detailed information klarmie. It's much appreciated.
My Magnum SXT/AWD (3.5L) has 99k miles on it so I'll be doing the work and buying the part myself. I reset the code this afternoon and will wait to see if it reoccurs
#13 ·
heres the service info.....
3.5L
  1. Disconnect negative battery cable.
  2. Remove purge solenoid from bracket.
  3. Relocate the purge solenoid.
  4. Unlock and disconnect the electrical connector from EGR valve.
  5. Remove the wiper module, (Refer to 8 - ELECTRICAL/WIPERS/WASHERS/WIPER MODULE - REMOVAL) .
  6. Remove shock tower brace and relocate.
  7. Remove the upper intake manifold, (Refer to 9 - ENGINE/MANIFOLDS/INTAKE MANIFOLD - REMOVAL) .
    1 - TUBE 2 - EGR VALVE
  8. EGR valve (2) and tube (1).
  9. Remove tube bolts (1) to EGR valve (3).
  10. Remove tube (1) from intake manifold.
  11. When removing EGR upper tube assembly being careful not to drop the silicone rubber seals in the intake manifold. Clean gasket surfaces on the EGR valve. Note that any loose dirt can lodge between the pintle and the seat and cause valve leakage that will give a rough idle and depressed manifold vacuum.
  12. Remove EGR valve mounting bolts (2).
  13. Remove EGR valve from vehicle.
  14. Clean mounting surface.
#15 ·
Far as I know yep as they have to clear codes etc..
Think they stick you with a Starscan for just about anything electrical related.
#16 ·
Just got mine back today - after being away up north for the weekend coming home engine light came on and it ran a bit rough. Took it into the dealership and P0406 was the problem - covered under warranty so no out of pocket expenses....other than the inconvenience - but Eastway as usual was great and because they did some add'l repair work I got a rental for the day.....the Daykota was a treat but heavy one the gas!!!!! Now I know why i don't have a truck!
#17 ·
Grrr.... I had been getting that code for a while and the first time i took it to the stealership, they told me that they could not replicate the problem and that all of the codes had been cleared. Can ran fine for a few months and started doing it again. I took it back and was told that I needed to have the EGR valve replaced and some throttle body maintenance done. Ok i say, and 3 days and 480 buks later i get my car back. Then I drove her the next day and now its a lot of hesistation or stuttering and some real bad vibration. Shes back in the shop now and I am waiting on the verdict. I hope the mechanics didnt screw something up because she wasnt doing that when i before i took it to them.
#19 ·
Good question, I got that code this past wed. at 69,500 miles and took it to the dealer this morning. The not very pleasent service writer (the guy was acting like he was doing me a favor just talking to me) told me that if the EGR was the problem that it iS NOT COVERED under 7/70 and that it would be $370.00 minus 15% for my dealer loyalty. I left to do some further investigation so her I am.....
#28 ·
I just did this install on the weekend. There are a couple of brackets that are stupid and very annoying to get off. I had to use a pry bar to get the 2 on the passenger side of the engine off so I could remove the intake! There is one mounted to the throttle body that seemed pointless so once it was time to put it back on, I neglected that part of the project.
Also, the EGR being behind the engine was so annoying to find the 2 holes where they went back into, maybe if I had one of those nifty cameras on a bendable fiber optic cable.
A note: once it's time to transfer the brass/copper tube onto the new EGR, you should mark it accordingly to the bracket so you have the right angle for it to be put back into the intake. I just guessed so HOPEFULLY I chose the right spot.
#29 ·
i just did this install on the weekend. There are a couple of brackets that are stupid and very annoying to get off. I had to use a pry bar to get the 2 on the passenger side of the engine off so i could remove the intake! There is one mounted to the throttle body that seemed pointless so once it was time to put it back on, i neglected that part of the project.
Also, the egr being behind the engine was so annoying to find the 2 holes where they went back into, maybe if i had one of those nifty cameras on a bendable fiber optic cable.
A note: Once it's time to transfer the brass/copper tube onto the new egr, you should mark it accordingly to the bracket so you have the right angle for it to be put back into the intake. I just guessed so hopefully i chose the right spot.
the 2 brackets on the pass. Side r easily removed if u loosed the 16mm bolts at the bottom of the bracket,no prying needed.
As far as the bracket on the throttle body. I would put that back on,if it was not needed the factory would have not put it on either.just my opinion.do it right the 1st time to save u time later..
