Hi folks, how do you remove the circular clips that hold the hood insulation to the underside of the hood? I tried to pry 2 and they snapped.
Thanks in advance.
Thanks in advance.
I did this with some black vinyl I got from a fabric store. The damn thing stays clean and if it does get a few spots on it ,simply wipe off. Makes the under hood look soooo much better.Thanks. Actually, if you could get some thin vinyl and sprayable contact cement, you could just wrap the original material with the vinyl. If it was thin enough, it would assume all the contours of the original piece and would be easy to wipe clean.
Howd you break the washer nozzle? I was power washing and I think I may have broken it as the driver side doesnt spray and the passenger side just trickles....So good end to the story. The washer nozzle was only $20 (Thanks AdamC!) and I found push pin type fasteners for $0.78 each at Partsource - I think Advanced Auto Parts for you're guyz in the US.
