installation of headers/cats/underdrive pulley
First of all, major props to my dad, roguese, for giving me his old school knowledge and confidence to get this done. couldn't have done it without him. i started taking apart the front end friday night/saturday night. this pic is already from after the pulley is installed, i forgot to snap one when i first took it off
Uploaded with
ImageShack.us
the pulley did give me some trouble because i went about it all wrong. its works best to pull from the inside with the jaw hooks facing the crankshaft nose. took me a while to figure it out. the special tool insert miller sells, 8513a, can be used but something equally as effective can be fashioned
http://www.lxforums.com/board/[URL=...http://img69.imageshack.us/img69/4576/img0703ky.jpg[/IMG][/URL] Uploaded with
Uploaded with
ImageShack.us
http://www.lxforums.com/board/[URL=...ttp://img819.imageshack.us/img819/6979/img0704d.jpg[/IMG][/URL] Uploaded with
Uploaded with
ImageShack.us
http://www.lxforums.com/board/[URL=...http://img34.imageshack.us/img34/1088/img0707qg.jpg[/IMG][/URL] Uploaded with
Uploaded with
ImageShack.us
i used a 3/8 drive 10mm socket with a 1/2 inch to 3/8 reducer behind it. the 10mm fit right inside the nose and since it is tapered up to fit a 3/8 ratchet it stops itself from going into the nose and allows you to pull it off fairly easily. New pulley installed and torqued to spec. i used a strap wrench and a block of wood to accomplish that
Uploaded with
ImageShack.us
Headers as everyone knows are a pain in the arse to install, only because the immense amount of patience it takes to do it on your back. i also did it without removing the motor mounts because i was a little scared of doing that. i am by no means a trained mechanic or one who actually has vast experience, just started doing my own work about a year ago so jacking up a motor and getting it all lined up right was not something i really wanted to try. I could see shaving a lot of time off if you did though. I did use the srt header bolts. I did drop the whole exhaust to remove the mid pipes. its really helps to get the 02 sensors out of the stock manifolds before unbolting. Drivers side was, dare i say, actually pretty easy to get off. Passenger side was, as been well documented, a hell of a lot more annoying
[URL=http://img199.imageshack.us/i/img0705ak.jpg/]
Uploaded with [/URL]
ImageShack.us
i actually removed the driver side sunday evening and snapped some pics early monday
[URL=http://imageshack.us/photo/my-images/14/img0709ad.jpg/]
ImageShack.us
driver side installed
[URL=http://imageshack.us/photo/my-images/687/img0717qh.jpg/]
ImageShack.us
passenger side stock and then new
[URL=http://imageshack.us/photo/my-images/217/img0712i.jpg/]
ImageShack.us
[URL=http://imageshack.us/photo/my-images/840/img0720o.jpg/]
ImageShack.us
and to top it all off
[URL=http://imageshack.us/photo/my-images/12/img0722m.jpg/]
ImageShack.us
