gooeytek
JV Young
2005 Dodge Magnum RT
Brilliant Black
"P" Package
Arrington 6.1-based 392 shortblock:
- K1 Forged Crankshaft 3.795 Stroke, 2.0997 Rod journals, 2.5588 Main Journals
- K1 Forged H-Beam Rods, 6.200" length, 2.225 journal, .927 Pin, ARP Rod Bolts
- Mahle 2618 Dished Forged Pistons, 4.0565 Dia., 1.5x1.5x3.0 Steel Ring Package
- Clevite Hardened Rods and Main Bearings
- ARP Main Studs
- Arrington Balance and Blueprint of Short Block
- Deburring of Block
- Stroker Clearancing
- Sonic Checked Cylinder Walls
- Chamfer of all Cylinder Bores and Lifter Gallies
- NASCAR-finished Block and Mains
Arrington ported and polished Eagle heads
General PH6S Specifications:
- CNC Ported
- Single Point Cut CNC Valve Job on a Newen Epoc CNC
- Upgraded:
- PSI 1511 Springs
- Hardened Steel Retainers
- Hardened Steel Locators
- Viton Valve Seals
- Capable of up to .625" Lift
'09 Eagle valve covers
'06 PCM reprogrammed and reflashed by AJ/Hemituner
Arrington X-Series CC607 Camshaft
- Hydraulic Roller Lifter high performance Camshaft
- 8620 Steel Billet Core
- Duration @ .050": 227/233 (intake/exhaust)
- Valve lift: .607"/.607" (intake/exhaust)
- Lobe Sep. Angle: 116deg.
Ported 6.1 intake manifold by Dave Weber
- Fuel Injector Clinic 900cc/88lb injectors
- Fore Precision billet fuel rails
- Fore/BMC braided fuel line kit
Paramount SFI-spec registered flexplate
Precision Industries 2800 Stall Converter
Powerbond 25% underdrive pulley
Jet-Hot'd SRT manifolds
ceramic-coated catless midpipes
Volant SRT catback
Suspension and chassis:
- KSport Coilovers
- Hotchkis front and rear swaybars
- Stack Performance strut tower brace
- B&M Tranny cooler
- CFR Power Steering cooler
- SRT Radiator w/ 176 t-stat
- Stoptech ST-60 6-piston front calipers
- Stoptech 14" front vented and slotted rotors
- Stoptech ST-40 4-piston rear calipers
- Stoptech 13.2" rear vented and slotted rotors
- Stoptech stainless braided brake lines
- Stoptech street pads/EBC BlueStuff for track
Blue Top solenoids
MSRT Wheels powdercoated satin black
VIS CF SRT hood w/ tri-jet Tiburon washer nozzles and custom billet hoodpins
Frankentake IV
BT Underhood Stuffs & wheel center caps
SRT TCM
AMG Paddle Shifters
Danko 'cuda grille & chin spoiler
R&T front + SRT rear seats
rear wiper delete with custom designed wing emblem
Zeitronix ZT-2 wideband
TranZformer and NoESP by zautotech
...and I think I'm done. (maybe)
