I have been considering going from an open 3.06 to a Getrag 3.06 but am not sure its a necessity in my case as much as an obsession or for bragging rights.
I have a mildly Supercharged (7psi max) 2013 5.7L, stock manifolds into a Corsa CatBack. And an upgraded cooling system.
I have never ran it at a strip but am curious. I have even acquired a spare set of 2 wheels putting on Atturo Z850's for a trip to a strip this spring which I don't see becoming a habit. A total rookie at launching.
Traction control on this car seems to work damn well and I have yet to do a one wheel spinning launch or romp or in the wet. Even when press the TC button for a partial off.
When I play its rarely from an off the line.
I read a 2006 post about under heavy use the clutches and springs will wear out, which I'll not be putting one through, and get recommendations to buy used and replace with better aftermarket sets. I am capable of performing it.
In my research I read lots of posts on the Challenger forums about a common Getrag gear wine mostly in the 40mph areas.
So I'm thinking I may just want to pass on the notion. I wonder if since 2006 if the clutches have been upgraded in later units or if there any other side effects over an open diff.
Thanks
Thanks
