I'm getting ready to take the plunge and buy a kenne bell set up for my 6.1, other than its gross overkill for a stock 6.1 is there any good reason to get a 2.8 instead of a 3.6LC other than the obvious price difference, I plan to run minimal boost either way till I get a bullet proof driveline installed and the internals replaced with a forged low compression 426 stroker, I want to get the biggest expense out of the way first, and I'm sure the 2.8 would make more than enough power even for a 426, but its there any down side to just starting with the 3.6 and upping the boost later... well and does anyone know if it will clear a stock '07 magnum hood? I've heard it the same height only wider?
