Rodents.Is this normal wear and tear? or rodents chewing on these wires?
Do you know, does it terminate at a firewall plug, or do the wires pass through?That's the TCM harness on a nag, runs by itself all the way from trans to the TCM
Sent from my LE2117 using Tapatalk
So, I would rather replace the entire loom rather than repair.The harness runs straight from the twist lock connector on the front right of the trans, up over the trans and may or may not still be loomed up with the rest of the wiring that lays on the top of the trans bell, eventually breaks out of that and runs to the firewall, then just through the inside right to the TCM and plugs in
Any vehicle that had the nag will have this harnessSo, I would rather replace the entire loom rather than repair.
I have discovered this is a discontinued item.
is this loom the same across the LX platform?
That is a handy piece of info. I need to find a replacement harness.Any vehicle that had the nag will have this harness
