1 - 16 of 16 Posts
· Damn Fast Grandpa!!
I have my two original keys ( they still work, barely). When I get to the step of putting the new key in the sentry light never stops flashing and I don't get the chime after ten seconds as the manual says should indicate a successful setup. I have the remote start setup also, I have the feeling this is what is giving me trouble, but I don't know how to get around it. I tried setting the remote start to 30 second on delay and including it in the programing but have had no luck.
Key is reved to 05183348AA from original 56038751AE. I am hoping they are still compatible.
Yes. Mopar start. You were in the right book.
Discussion Starter · #6 ·
Thats the number on my original key. I even got out my "old man" glasses and rechecked!
Discussion Starter · #8 ·
fnkychkn said:
try removing the SKREEM interface antenna from around the key halo and retry programming.
Sounds like a plan. I will give it a try when the Magnum comes home from NY.
Discussion Starter · #10 ·
My worry is that the remote start transmitter may need to be purged from memory before I can program any more keys.
Discussion Starter · #13 ·
It seems to function ok. I tried at least 20 times in different sequences sometimes using the remote start as one of the good keys and sometimes just using the good keys. The owners manual says two keys are needed. If there are three keys, do you still only need 2?
Discussion Starter · #14 ·
Is it too late to call and peck er I mean pick your brain?
Discussion Starter · #16 ·
got it
1 - 16 of 16 Posts
