Tuner said I have plenty of pump (arrington drop in)and (Demon)injectors. Torqstorm with an arrington 85 mm tb and borla atak cat back. my afr is between 14 and 15Having trouble getting the AFR right on my torqstorm install. What could be the reasons why it is lean? keep adding fuel and it stays lean.
Unless you're running E85, that's where you want it to be. 14.7 is stoich, so you're not in tha danger zone.Tuner said I have plenty of pump (arrington drop in)and (Demon)injectors. Torqstorm with an arrington 85 mm tb and borla atak cat back. my afr is between 14 and 15
That fine for cruising/ idle.Unless you're running E85, that's where you want it to be. 14.7 is stoich, so you're not in tha danger zone.
Sent from my SM-F926U using Tapatalk
Where are you adding the fuel?Having trouble getting the AFR right on my torqstorm install. What could be the reasons why it is lean? keep adding fuel and it stays lean.
At WOT it goes leaner than 14 and up he keeps adding fuel at WOT. Fuel pressure is good. Could a bad AFR location cause these readings? It's brand new but I'm not sure where it was positioned in the pipeWhere are you adding the fuel?
When is it lean?
We need more details to help.
What’s ‘good’ fuel pressure?At WOT it goes leaner than 14 and up he keeps adding fuel at WOT. Fuel pressure is good. Could a bad AFR location cause these readings? It's brand new but I'm not sure where it was positioned in the pipe
Idk. He’s a 4 year memberTotally BS post, guy comes out saying I'm lean. Heh. I'm thinking troll.
58 psi at the rail. I am not tuning it so i do not know anything except the tuner said the injector duty is too high for 6lbs of boost. I do not have a pic of the log Its at a shopWhat’s ‘good’ fuel pressure?
What’s the duty cycle of the injectors look like?
Can you post a pic of the log?
My fuel pump is only providing 38-40 lbs at WOT. will a hellcat fuel pump work in my car?58 psi at the rail. I am not tuning it so i do not know anything except the tuner said the injector duty is too high for 6lbs of boost. I do not have a pic of the log Its at a shop
Gapi what am I trolling for? Im looking for advice from people with more knowledge then I have about this. I guess I will delete the post
Do not use a hellcat pump. There are way too many issues with wiring not corresponding and frying themselves.My fuel pump is only providing 38-40 lbs at WOT. will a hellcat fuel pump work in my car?
That still won't flow enough. Most likely going to need a dual hat set up to provide the flow and pressure needed for boost.Why not use a late model SRT8 pump?
