And don't even consider doing aux fuel injectors for the extra fuel. Go with larger injectors and figure out how to tune it that way.The motor should be able to handle the 1000 kit without any real problems IF IF IF IF IF you get it tuned properly. If you put boost on top of it, or go with the 1500 kit, you may want to consider a forged bottom end (crank, pistons, connecting rods, wrist pins, cap bolts). Then I'd imagine you're good to the mechanical limits of the tranny, driveshaft, rear end, axles, etc. I believe someone said the tranny is good for 700hp.
I have heard of 6.1 motors blowing on the s/c kits as well. Not something the people it happens to want to talk about, but it has happened. In my book they just aren't safe.It's ok to do on the 6.1's, but the 5.7 cannot handle forced induction unless it is tuned very well.
I would say no on the supercharger kit until somone does it the right way and actually test the cars before production.I got someone offering me a Novi 1000. Should I get it? What else do I need?
Is it better than Nitrous?
I not going to rule out and say a SC is not safe..Now the current kit that is sending a lot of our fellow HEMIs to there maker...HELL YEAH. I knew something was up when I saw that low budget aux injector setup that who ever bought the kit is in for a nice ass bang.:doh:I have heard of 6.1 motors blowing on the s/c kits as well. Not something the people it happens to want to talk about, but it has happened. In my book they just aren't safe.
Your on the money about the injector set-up. But our piston design blows................hahaha...........get-it "blows".............Uh ya OK, I'll shut up now.I not going to rule out and say a SC is not safe..Now the current kit that is sending a lot of our fellow HEMIs to there maker...HELL YEAH. I knew something was up when I saw that low budget aux injector setup that who ever bought the kit is in for a nice ass bang.:doh:
your right, some what..lower compression will just give you a bigger window for tunning..Higher compression you have less room to play with..I bet if the current kit was put back into testing with 8 injectors, return line, aeromotive fpr, and something to control all these goodies..things would look a lot better on the bright side..Now don't read to deep into my post..im not saying you would be able to run some serious boost..but the 5 psi that people are blowing there motors with should be a cake walk..anything higher I would recommend dumping some money into the motor.you build the motor first.
Bolt it on and play with fire. Can you afford catastrophic engine failure and expensive repair?
No one with any experience puts boost to a stock motor with high compression. A little spent up front will greatly reward you down the line.
So I take it that you finally got your answer about the bottom end.Even with the bullet proof motor they custom built for me, it lasted a whopping 6 months. But if you have cash in your hand your their best friend and they will bend over all kinds of ways to kiss your @$$ once they have your cash, you'll be lucky to get them to return your voice mail.
I got the answer from them when I called and told Scott the motor let loose. Asked about warranty since he built it and tuned it, said sorry its custom HP no warranty.So I take it that you finally got your answer about the bottom end.
Sorry bud :sad:
So what do you think caused it this time??.
Find pieces of your piston on the oil pan? i bet cyl 1 went lean and melted down.. Pretty crappy that they would not stand behind their engine work. :doh:I got the answer from them when I called and told Scott the motor let loose. Asked about warranty since he built it and tuned it, said sorry its custom HP no warranty.
I still don't know what happened to mine, right now riding a BMW R1150RT to get to work, end of October I start working from home for a month and a half so that will allow me time in the evenings to tear into it.
Now if I could get those HEAT guys to ship me a motor...
Yeah, all motor is looking more and more better these days..but 5 psi should be a walk in the park with the right fuel system and tunning of course.:loser:Find pieces of your piston on the oil pan? i bet cyl 1 went lean and melted down.. Pretty crappy that they would not stand behind their engine work. :doh:
Maybe with a proper fuel system they could handle a little boost.. I think the best way for us to make power is with cam, heads and spray..
Oh, and vinyl.. I hear graphics add horsepower too.
Those guys are a bunch of a$$holes...sorry to hear that man.I got the answer from them when I called and told Scott the motor let loose. Asked about warranty since he built it and tuned it, said sorry its custom HP no warranty.
