Must still be noisy then!
If you look at the glass (with the roof closed) you should see allen head bolts holding the glass to the frame check to see if they are still tight. if not make sure the glass is in the right place(leval with roof) and retightn the bolts!
Or take it to the dealer it's under warrenty right!
