It be me haha, here is the pic of the socket that's there when they inserts are removed. Screwdriver on the outer edges of the wheel. the inner are placed under the horn/airbag cover. Dont forget to put the inner side in first, its a bear to pull the cover over it once they are in.Aikidoka said:There was a post about two weeks ago where someone pulled them and color matched them. If I remember you just have to use a small screwdriver from the top and bottom and pry inwards and they will come right out.
Hope that helps.
