Did you also run the eight rib that comes with the stage 2 ? Good to know , I'll be looking out for it.I have the same set up on my Scat . D1X,helical gears,race intercooler and Red BOV. keep a close eye on all the pulleys and watch for tensioner pulley contacting the bottom of the air plenum when adjusting the belt tension .you may need a shorter belt than the manual states.. I did.
Yes, one of the very first 8 ribs to come out.Did you also run the eight rib that comes with the stage 2 ? Good to know , I'll be looking out for it.
Do you have a PN for the belt you're using ?Yes, one of the very first 8 ribs to come out.
Gates green belt. K080677HDDo you have a PN for the belt you're using ?
Sweet, thank youGates green belt. K080677HD
3.4 Pulley with an 18% over ATI lower. Primary fuel pump is a Walbro 342. secondary is a TI 285. Fore rails. all lines are -8. keep in mind, I have a 9.5:1 Hellcat short block . you will make a lot more power with your set up.Sweet, thank youone more question , sorry. What fuel pump and size pulley are you running at 750whp? Just ordered that belt.
Well, while they may have discontinued the tuner, I think there are enough people that did get them and have shared the stock tune file. I think it would be pretty easy to get.Ditto what wink said - Big congrats, she should be a monster.
Interesting on the edelbrock, wonder what their reasoning is behind that.
They discontinued the tuner kit, that option is no longer available . I didn't want the tune file for the edelbrock. I didn't want the injectors, bap , tuner , etc ... all that comes with the full kit. Now , you HAVE to buy the full kit which is about 1600$ more than the tuner kit.Well, while they may have discontinued the tuner, I think there are enough people that did get them and have shared the stock tune file. I think it would be pretty easy to get.
In fact, I was over on the HP Tuners forum and there was a guy asking for just that. He saved $1500 by buying the Edelbrock supercharger kit from a dealer without the tuner. Someone on the forum shared with him the original stock read using HP Tuners after loading it from the Edelbrock tuner.
Ohhh haha I understand now. I guess it must be that they weren't making enough on the tuner kit unfortunately.They discontinued the tuner kit, that option is no longer available . I didn't want the tune file for the edelbrock. I didn't want the injectors, bap , tuner , etc ... all that comes with the full kit. Now , you HAVE to buy the full kit which is about 1600$ more than the tuner kit.
Alex used NGK 5107's in mine .. which is the exact same as dcmx's plugLast question fellas , I promise(definitely not).
What plugs are you guys running. I was looking at the brisk rr12s , are those too cold ? Should I use the rr14s?
Nice , a little cheaper than the brisk tooAlex used NGK 5107's in mine .. which is the exact same as dcmx's plug
Sent from my moto z4 using Tapatalk
ronan wouldn't have used the Edelbrock tune anyway but yes it does suck. the 2650 on my 5.7 Charger made 340/399 with the Edelbrock tune and 500/492 with a real tune. . part throttle drive ability was surprisingly good but the car would stutter at WOT. tune was incredibly fat..Just so you guys know the edelbrock tune sucks, and I mean SUCKS. I think for you,you went the right route
