Never got the RKE low battey error in my EVIC. Must be the extended EVIC with the TPMS readout instead of the idiot light... the 300C is an upscale LX after all :mrgreen:
What is this WCM antenna and wrap around? I have the extended range remote start module from Dodge with a black box and 2 rubber antennas mounted on the windshield just above the mirror.
the ignition has the WCM antenna wrapped around it to pick up the RFID from the key, it is a black plastic circle around the ignition switch (you need to remove the dash panel to see it)
the remote start has an antenna that wraps around that module so send the RKE (RFID) to the ignition module (like holding the key in front of the ignition switch)
it has nothing to do with your remote start range antenna, this is the SKREEM module that sends the learned RFID to the cars PCM.
with the SKREEM module antenna wrapped around the SKIM module antenna it reduces the RKE distance..
as for the RKE error in the EVIC, it is there, it happens with ALL remote start units for the LX modules 2005 thru 2007, you probably never see it because it times out before you get in the car, the RKE error has nothing to to with the WCM's for the TPMS, 2 entirely different systems and different modules.
