Unless you have exhaust leak you need a new converter. I think the photo is a blind hole. Maybe needed for truck applications.
Yeah I do have to pass an emission test (in a few months). I'm going to look around the driver's side exhaust manifold and connector going to the down pipe. I think I hear a slight leak. Could be that's what is throwing the code. Worst comes worst I'll replace the cat. Thanks for the info.P0420 is the engine computer comparing the upper and lower O2 sensors and deciding your catalytic converter isn't doing enough. Could be as simple as somebody punched a hole in it because it was clogged. You can ignore it pretty much unless where you live you have to pass a smog test.
