Can anyone tell me if I should have piston to valve clearance with my stock pistons with a big Hughes engines hydraulic roller for my 2004 n/a stock bottom end 5.7 . I’m running the ‘09 and up eagle heads with the 2.05 intake valve diameter with a .075 Cometic MLS gasket . The cam specs will be 246 int. , 250 exh. Duration at .050, .611 int. .622 exh. Lift, and a 110 or 109 lobe seperation angle not decided yet. Would I have to flycut the pistons to clear the valves? Thanks for your time.
