2009 Chrysler 300 LX 2.7 Red oil light on dash on continuously some days and off all day other days, Checked pressure with a gauge - normal .Replaced oil pressure sensor with mopar part - same symptoms. I want to check wiring - this is the single wire type sensor , wiring diagrams I found here only show the 3 wire sensor used in the V8,
Want to trace the wire from oil pressure sensor to I assume it goes to PCM but no idea what connector and pin.
Any help appreciated
