1 - 12 of 12 Posts
Doing an install on a Hummer H2 of an alpine z3. Just about done and everything is working just that the damn fm antenna wont click in, it will lay in the hole of the radio if i hold it there and get perfect signal, let go of it or move it it will just fall out. Any help?
Discussion Starter · #6 ·
Also i tried just grounding the parking brake wire to the ground wire used for the head unit and i guess that doesnt work to allow playing while the parking brake is off? What if i attach a switch will that work?
· lil Red Wagon
2008 H2 with Pioneer AVIC-Z3 [remove]
This item Fits
Not sure on the video hack side of things ..
Discussion Starter · #9 ·
Yea it says it fits, maybe they forgot to put it in there because it says supplied, but it didn't come with it.
· lil Red Wagon
don't know there but every GM 1995ish and up that I've swapped a HU in has needed one so I don't see the Hummer being any different..
the factory end looks the same but is just a bit smaller then the After Market plugs..
1 - 12 of 12 Posts
