I have one Question, are your "stock " pistons, OEM Mahle or one of the aftermarket stock Cast piston? there are two major issues with the Mahle as run 03-08 factory pistons , 1) the top ring land was too close to the top of the piston, which they changed for the 09 and later 5.7s, the other issue was the stock ring gap was too tight , something in the .008-010 range, considering the location of the top ringland , DHJ and Enginetech after market pistons have the top ring land down where the 09+ 5.7s have them.the Guys I bought my Solar Yellow 05 GTxtreme from had rebuilt the stock 5.7 with Enginetech pistons, stock 5.7 crank and reworked stock 5.7 rods from the org 5.7 engine. Gaped the top rings at .018 ran an Arrington NOS Throttle body, they ran the truck with both a 150 and a 250 jet, ,Howards Camshaft 786045-14; .600/.600" and stockish Eagle heads and Jeep intake manifold, with a MSD window switch set at 4800 , When I bought the truck the rebuild had 35k on it, pulled it apart and you could see the rod bearing were hammered on bad, I think 100/150 shot only would have been the safer bet , but the Engintech cheapies pistons held up well. 3 of the stock rods had a slight bow in them, which was only visible when all 8 rods were laying on top of each other, personally I think in another 5k one of the rods would of given up, again I think if it was limited to a 100/150 shot it would be fine.truck ran in the 11.20s range with the 150 shot and 10.50s with the 250
[email protected] 4550 race weight on my buddy Vince's mustang chassis dyno it had an average of 495/565 HP/TQ with a 727 trans behind it. ...now keep in mind that this truck had the AC deleted and ran an electric water pump. Alternator and power steering/hydro boost pump where the only assecories :::::::::::::::::::::::::::::::::::::: (9/14) just realized my typo in the HP/TQ Numbers should be 495/515 , Not 565 my apologies for the typo also the Jeep Intake manifold on this engine was the custom SRT8 Intake from America's most wanted 4x4 , it was not the stock jeep intake..
