Need a pic of this thing and the proper orientation of the black strap that unlocks the trunk. Mine needs getting stuck under the white comma shaped thing when it turns back to the resting position and keeps it from locking. Got to the point now where it's popped that lever out of its slot and won't unlock without the key now. Just need the pics to double check that straps' orientation. Will require removal of the two 8mm plastic push pins holding the black cover on it. May also require removal of the two 10mm bolts holding the actuator assembly on for a good pic. Thank you in advance.
Sent from my LE2117 using Tapatalk
