I have parted out 4 SRT8 over the last couple of years and have a lot of small items left. All priced to sell to clear out my basement. Here is the list and some pics. Can send pics of whatever you might want.
Electrical
’06-’08 LX Clock Spring 2006 - 2008 Chrysler Magnum 300 Steering Clock Spring OEM Part No. 0WU82XXXAG (check your part no please) $48 shipped
  • ‘06-‘10 LX-LC Headlight Switch P68019789AE OEM $24 shipped
  • ’06-’10 LX-LC Headlight Switch (separate fog light button) L0020314AF OEM $32 shipped
  • ’08-’10 Chrysler 300 Wireless Ignition Node w/key OEM Part no. P68290854AB $92 shipped
  • ’05-’10 LX ABS Hydraulic Control Unit part no 506730002AF $72 shipped
  • ‘05-’10 LX Positive battery cable and ends. Runs from Battery to firewall and includes the rear fusebox positive cable(discontinued) 04759976AE $62 shipped
  • ’05-’07 LX Starter wiring harness part no.05029980AC (discontinued) $88 shipped
  • Nag1 (3) large connectors with O-ring that plugs into Transmission. Exc, Condition. Have 3. $18 each or $34 shipped for all three
  • “08-’10 LX center dash air vents $35pair shipped
  • 2005 Rec/Nav front faceplate $22 shipped
  • Rec/Nav AM/FM/CD Sirius radio. (Part No. P56038646AL) $199 shipped Fits:
2008 - 2010 Jeep Commander 2008 - 2010 Jeep Grand Cherokee
2009 - 2013 Jeep Compass 2009 - 2013 Jeep Patriot
2007 - 2010 Chrysler Sebring 2008 - 2009 Chrysler Aspen
2008 - 2010 Chrysler 300 Series 2011 - 2014 Chrysler 200 Series
2007 - 2014 Avenger 2009 - 2012 Caliber
2008 - 2013 Challenger SRT8 and R/T 2008 - 2010 Charger
2008 - 2008 Magnum /2008 - 2011 Dakota/ 2008 - 2009 Durango
  • 2008 Power Control Module (PCM or ECM). $215 shipped
  • 2007 Power Control Module (PCM or ECM). Part No P05094811AE $215 shipped
  • 2005 -10 Parking Assist Module $40 shipped
  • “07 Front Control Module (FCM) (Part No. P04692230AF)
  • 2007 LX TIPM Exc Condition $68 shipped
  • 2008 LX TIPM Exc Condition $68 shipped
  • ’06-’08 Chrysler 300 Electronic Stability Module (Dynamic Sensor) OEM 56029328 $92 shipped
  • ’05-’10 LX Rear Power Distribution Center (Fuse Box) including Rear Facia wiring. (Part no. 4855600AB) Harness extends to under rear seat where it was cut. $99 shipped
  • Alternator(2) LX, LC one fits ‘05’07, 2nd fits ’08-14 5.7&6.1 $55ea shipped.
  • All 4 wheel ABS Sensors Exc Condition $25 shipped
Interior/Body
  • ’05-’08 Magnum, ’05-’10 Chrysler 300. Doors in Perfect condition, no rust, no dents or scratched. Have LF, RF and RR. . Will not ship, will deliver within reason along the way to any Modern Street Hemi event. Can deliver locally for a fee. $150
  • ’08, ‘09,’10 rear deck (trunk) lid. Excellent condition. Will not ship, will deliver within reason along the way to any Modern Street Hemi event. Can deliver locally for a fee. $150
  • ’05 ’-‘18 SRT Tire Air Compressor Part No. 5170750AA (discontinued, hard to find.) $88 shipped
  • ’08-‘10 LX lighted visors with mirrors and visor clips - $65pair shipped
  • ‘05-’07 LX Console includes rubber insert, fold out cupholder, rear panel and vent cover trim- no lid - $75 with chrome shifter surround trim - $100
  • ’08-’10 LX Console includes lid, rubber insert, shifter/cuphold trim, rear panel and vent cover trim - $150
  • ‘05-‘07 LX Shifter surround trim for console - $26 shipped
  • ‘05’-’07 Charger-Magnum Dash (cluster) Panel $48 shipped
  • ‘05-10’ Chry 300 door opening weatherstripping VGC All 4 doors (will not separate $125 shipped
  • ‘05-’10 LX Power adjustable brake pedal assembly $55 shipped
  • ’05-’07 LX Parking brake pedal and assembly $58 shipped
Engine/Transmission
  • ’01-’07 LX, Intrepid, Sebring Purge Solenoid PartNo.04591733AA $19 shipped
  • ’08-’19 LX, LC Most Chry/Dodge Purge Solenoid PartNo 4891738AA $19 shipped
  • Evap Line for purge solenoid $15 shipped
  • ’05-’07 LX Nag1 shifter assembly, includes shift cable to trans. $99 shipped
  • ‘05-’07 LX Throttle pedal $55
  • ’05-’15 LX, LC Fuel pump/basket VGC $47 shipped
  • Knock sensor shields 4pcs $20 shipped
  • ’05-’10 LX, LC Driveshaft Heat Shield $30 shipped
  • ’05-’10 LX, LC Motor Mount Heat Shields 3 pr L&R$20pr shipped
  • “05-’10 LX, LC Sway Bar Bushing Heat Shields $19pr shipped
  • ’05-’10 LX, LC L&R motor mount supports& alt brace $49 shipped for all shipped
  • 5.7, 6.1 Motorad 180* thermostat. New $19 shipped, used in good shape $13
  • ‘5-’10 LX Windshield washer hose $19 shipped
  • ’05-’10 LX Wiper arms pr. $22 shipped
  • ’05-’10 LX wiper transmission assembly with motor $65 shipped
  • ’05-Fuel pump basket and pump- good condition $50 shipped
  • 6.1 Dipstick and Tube. Will only work with stock exh manifolds. $30 shipped
  • ’05-’10 LX Power Brake Booster $38 shipped
  • ’05-’10 5.7, 6.1 Throttle Body $57 shipped
Miscellaneous
  • 6.1 Hemi Coil Covers – need repainting $45 shipped
  • Complete set of insulating tins for swaybar, above mufflers, motor mounts, etc. $35 shipped
  • ‘05-’10 LX, LC 2 sets of 5 exhaust rubber hangars and supports. One set with exh manifold spring nuts. $25 set shipped
  • ’05-’10 LX Lower intermediate steering column shaft $28 shipped
  • ‘05-’10 LX Steering column. No air bag or clock spring $65 shipped
  • ’05-’10 LX Wiper transmission and wiper motor $58 shipped
  • ’05-’07 LX Master cylinder with reservoir $44 shipped
  • Monster Cable – 18 ft. 0/1 gauge with ends $42 shipped
  • 2 cooling fan motors without the fans. $25 Shipped
