I just recently rebuilt my 2005 5.7 and put a new Melling high volume oil pump on it. I intended to use the pressure spring with the stock value, but that got overlooked and the pump still has the high pressure spring in it. The oil pressure switch/sensor was damaged during the rebuild and would only read 0 psi or 50 psi, so I replaced it. Now I get an engine light and a high oil pressure code.
How are you guys with HV/HP pumps remedying this?
