1 - 11 of 11 Posts
I have found a great deal on a set of chrome rims made by Maas.Its the style M52 or maybe the style M53.But for 22X9.5" rims with tires mounted and balanced is $1750 including tax.
Does anyone have thses rims?Please take at look at there site and let me know what yall think.
www.maaswheels.com either style M52 or M53.
Is it hot in here or is it just me?
The M53 is nice, but personally I like the M54 better. Have you considered that one and if so is there a difference in price?
All Black Everything!!!
does anyone take the weight of aftermarket wheels into consideration, as far as affecting performance too much etc...just wondering cause i have to see anyone ask about wheels weight around here, not knocking anyone in any way, just curious, as to oem wheel weight, from the SE up to r/t, so that it can be compared against the aftermarket wheel weight, and u know just how much more unsprung weight u are adding and or rotational mass as well..
thanks..
Aged to Perfection, Old Guys Rule!
thanks..
It has been discussed quite a bit on other threads. For instance............
http://www.lxforums.com/board/showthread.php?t=36260&highlight=wheel+weight
http://www.lxforums.com/board/showthread.php?t=29948&highlight=wheel+weight
Those are two of mine. Do a search and you will find many more.
shane93nc said:
And also what tire size is best when running a 22" rim?
Shane,
The best tire size and most commonly used is 265/35-22. This size does a number of things well:
1. Reasonably low profile while maintaining comfortable ride quality and improving handling.
2. Keeps your speedometer and final drive ratio very close (within 3%) to stock.
3. Gives the right amount of extra width without causing clearance/rubbing problems.
4. It's a common size now and easy to find and get good deals on.
Discussion Starter · #11 ·
VanillaRT4me said:
Shane,
Thanks for that!That was what I was wanting to know.
1 - 11 of 11 Posts
