It took me a while to pull the trigger and order these. I could have made them in the machine shop at work. And I actually drew each piece up in Solidworks with all the dimensions because I'm a nerd Engineer like that after I got them. But because I have little or no extra time these days, I decided to order a set.
Anyways, I installed the Lift Pad Pros Front Jack Pad's on my 2021 Charger Scat Pack Wide Body. Pretty easy install. The only PITA part is getting the aluminum insert in the frame rail and making it stay in place when threading the bolt into it. Took about 5 minutes per side.
Lift Pad Pros 2017-2021 Dodge Charger Scat Pack Widebody Front Jack Pad Install
If you want to purchase these, Amazon sells both the front and rear together in a kit here: Amazon.com: Lift Pad Pros - Jack Pad Kit - Made in USA (2008-2016 Front/Rear) : Automotive
