I have made an inquiry to the Manufacturers rep to see what it will take to get a shipment of the RKJXT1E12001 ALPS joystick. This is the unit with the shorter shaft that some have replaced the joystick with.
The older Joysticks are in, end of life production. This rep is going to make a final purchase of these units, I have inquired to purchase a minimum quantity of these units (100-200) units. This means these joystcks will never be manufactured by ALPS again. I have tried to find another manufacturer of this unit but no luck.
The replacement unit that I have now is not the exact replacement, it is only a 4 position output unit. The feel of the the new unit is the same as the old unit, in my opinion the new encoder will work but it would require more turns. Also this encoder is a little taller.
I will experiment with the newer unit in the futrue, but until I get answer, this is all I have for now.
Raymond
Raymond
