looking to get the stage 2 jet chip.... with the mods I have will the stage 2 work???
looking for more horsepower off the line
Yes, TATTOOD, your car qualifies fully for the Jet Chip stage II. Power and driveability differences will be immediately noticeable to you post install.
For the not-uncommon price of $150 for a used Stage II Jet Chip there is no better value in terms of a performance mod for your 5.7L Hemi. To the surprise of the many uninformed who opine on the Jet Chip, it not only gives your engine an immediate power boost by means of much more agressive fuel and timing management, but it gives your tranny a much needed boost as well by raising tranny pressure noticeably. Shift lag becomes a forgotten nuisance. See my post here to examine the benefits provided by each of the various mods I've added in my quest for perfection of the 5.7 Hemi:
http://www.lxforums.com/board/showthread.php?t=17243&highlight=modding+hemi
If I didn't need the Superchips tuner to raise the speed limiter I'd have never purchased it. Several tests show the Jet Chip to produce more power than does the Superchips tuner, and it has a better fuel map. I had to add the Jet Chip back on top of the Superchips tuner to cure a lean surge at high speed, something that had never occurred when using the Jet Chip, under any circumstances.
Even at supporting vendor pricing you can't go wrong with the Stage II Jet Chip, IMO.
Also consider the Robert Shaw 383-170 176-degree failsafe thermostat and the GSM fan/torque/ESP mod. You can read more about the cooler tstats here:
http://www.lxforums.com/board/showthread.php?t=19830&highlight
A cooler tstat is in reality only half a mod, needing a fan mod to keep your engine cool in town and in heavy road traffic.
Only the GSM fan/torque/ESP mod will allow you to totally disable ESP interference with your power application. The on-the-fly control it gives you over the radiator fan alone makes this a mod worth buying.
