1 - 20 of 52 Posts
· Boosted Fury
Here is the picture you have all been waiting for .. It made it's outside appearance( at least off the car ) at Performance World in Toronto
Enjoy, And dont drool on the keyboard
· Die hipster scum!
I'm curious about the crossover pipe running over the bellhousing. Is there sufficient real estate for that in the car? And if so, is heat going to be an issue up there?
· Formerly known as CANDYAPPLE
Fits all LX 5.7's. Will not fit Jeep SRT due to spacing problems. Heat not a problem with all the test miles logged so far. This thing works from well below freezing temperatures to excessive heat. 6.1 version not yet ready but 5.7's can have installs done in April.
See website www.conceptsonwheels.com/hemiturbo
Cheers CANDYAPPLE:beerchug:
· What part should we make next???
Where is the air intake?
In front of the turbo, sucking in all the road crap.
Obviously, it would need some sort of filter at the least, if not a pipe to take it somewhere cleaner. But you want some air flow to try and cool that baby off.
· We Shall Never Forget
The air intake was left off as per the conversation as not to get in the way of the good stuff. and it is violently fast in hitting boost. They are going to use a larger wheel in the turbo to slow down the spool. The crossover pipe has lots of room over the bellhousing and between the firewall and the engine.
Looks like a real quailty piece
· LX OG
It should be for that kind of money... I had the chance to talk to Kevin today at the show, although short lived he definitly seems to have crossed his "t's" and dotted his "i's" per say. I'm looking forward to learning more about the system from soon to be customers.
· No longer sporting dual R/T's!
Nice looking unit indeed...
Mike
· Boosted Fury
Discussion Starter · #19 ·
After the convertor it y's back to the stock dual exhaust. With the stock exhaust it is quiet.. With no Exhaust and just straight pipes it was heavenly.
at 4.5lbs of boost it made 400 rwhp and 470 lbs/ft .
1 - 20 of 52 Posts
