Hello, I'm trying to help my father get his 2006 Magnum SRT8 back on the road. He's the original owner and the car has 73K miles. He last drove the car in late 2019 before storing it indoors (ran perfectly when stored). I tired starting the car for him earlier this year and was unsuccessful. I figured after that much time the gas went bad. In September, I helped him drain both sides of the fuel tank. The inside of the tank looked very clean. We added 5 gallons of fresh gas, but the car didn't start. I pulled the fuel rail connection and realized zero fuel was making it to the engine while cranking. He lives several hours away and I have limited tools available in the location where its stored; so was unable to diagnose anything electrical. The car is a dry environment (Phoenix) and there are zero rodent or pest issues in its indoor location.
I suspect the fuel pump is bad. I'm going with the assumption that the driver's side (left) fuel pump is the one that feeds the engine and the right fuel pump balances the tank. If I'm mistaken and the passenger side pump can cause a no start situation, please let me know. I've researched aftermarket fuel pumps available from retailers like Rock Auto and Autozone and I cannot find any brands I recognize. I'm having a little difficulty finding the OE Mopar fuel pump online. Is there an aftermarket fuel pump brand with a good reputation or a recommended retailer that sells the Mopar fuel pump?
I'm visiting him again soon and really want to get the car running for him. I'm not afraid of the parts cannon approach given the lack a tool to confirm a proper diagnosis (could be a fuel pump relay?). Since a fuel pump can leave you stranded, I want to make sure I install a good quality part and look forward to your recommendations. Thanks!
