1 - 20 of 34 Posts
For a limited time we will be discounting our track proven Head and cam Packages along with the install kit.
We will be offering the following kits with your choice of camshaft. The special pricing is only on the head and cam combo, no discount will be given otherwise.
The packages are as follows:
5.7 Econo Head Package
Frank Racing Econo Port Heads - Made for those on a budget yet still want maximum performance These heads feature a 3/4 port of the Intake runner with only minor clean-up of the Exhaust port. Our time is spent reworking the bowl and work to the short turn.
Air flow is increase using a port design learned from years of experience. Frank Racing aims to allow these heads to be a true street performer and optimize low end torque.
The stock valves are used but with Frank Racing's 5 angle, comp valve job with matching seats.
These heads utilize a new spring, spring seats, guide is modified to use a teflon seal, and seals with the option of upgrade ferrera valves, bigger springs, and raised or lowered compression with combustion chamber work.
Benefits and Features
  • Our heads are on the fastest full weight street LX in the Nation which has run 12.4 on street tires
  • On an AWD, full weight car with simply the Econo heads and a Sidewinder, 13.3's have been attained
  • Gasket matched
  • Full port of the bowls
  • 5 angle valve job
  • Lapped valves
  • New seals, chase the guides, blue print spring height along with new springs.
  • Flows about 318cfm @ .600 lift
  • In Mexi's 300C, with these heads and a Sidewinder he has gone 12.4 with JBA shorties, Highflow mid pipes, a stock Daytona Exhaust, stock Torque Converter, an email tune and DR's
Package includes:
Normally $1,549.99, on Sale for $1399.99 + $150 for .030 milled deck if selected by the customer, along with Shipping Charges.
6.1 Econo Package
These heads utilize a new spring, spring seats, guide is modified to use a Teflon seal, and seals with the option of upgrade Ferrera valves, bigger springs, and raised or lowered compression with combustion chamber work.
Our heads are on the fastest full weight street LX in the Nation which has run 11.4 on street tires
  • [*]On an 5.7 powered, full weight car with simply the Econo heads and a Sidewinder, 12.6's have been attained with stock exhaust and tires
    [*]Gasket matched
    [*]Full port of the bowls
    [*]5 angle valve job
    [*]Lapped valves
    [*]New seals, chase the guides, blue print spring height along with new springs
    [*]Flows about 368cfm @ .600 lift
Package Includes:
Normally $1,529.99, on Sale for $1349.99, along with Shipping Charges.
5.7 Street/Strip Head Package
Frank Racing Street Heads are for more serious performance and a larger cam and free flowing exhaust. The Frank Racing Street Heads have a full port on both the exhaust and intake with full bowl work, chamber smoothing, and full chamber work.
These heads utilize a new spring, guide, and seals with the option of upgrade valves, bigger springs, and raised or lowered compression with combustion chamber work.
  • Our heads are on the fastest street LX in the Nation which has run 12.01
  • Gasket matched
  • Lapped valves
  • New seals, chase the guides, blue print spring height, with new springs
  • Frank Racing's comp 5 angle valve job with matching seats
  • And a full list of available options
  • Flows about 360 cfm @ .600 Lift.
  • With Sparrow camshaft and these same heads milled .030 Mikespy is running 12.1's in his 05 Magnum. Dynatech LT's, Bassani Exhaust, 2800 Stall, DR's and a perfect tune.
Package Includes:
Normally $2,159.99, on sale for $1949.99 + $150 for .030 milled deck if selected by the customer, along with Shipping Charges.
6.1 Street/Strip Package
  • Our heads are on the fastest full weight street LX in the Nation which has run 11.4
  • Gasket matched
  • Lapped valves
  • New seals, new valve springs chase the guides, blue print spring height
  • Flow's 380 cfm @ .600 lift
Package Includes:
Normally $2,154.99, on sale for $1899.99, along with Shipping Charges.
These prices shown are only valid for orders placed after Sunday January 4th, 2009 and they will remain valid until January 31st 2009, so hurry up and place your order today.
Also, we can cater to local installs if you are in or around the Houston area. We have very competive install rates, and with further savings if you choose to have additional work done at that point in time. Furthermore, if you choose to have us do the install here in Houston or take it to one of our many installers across the nation for your install your core charge will be WAIVED.
The core charge on 5.7 heads is $500 and 6.1 heads have a $1000 core charge.
  • You have 30 Days from the date of invoice to ship back your original/core set of heads in perfect condition
  • When your original/core set of heads is returned in perfect condition your core charge is refunded via check or credit card
  • The core charge will be waived if you send your original/core heads down first to be reworked.
  • The customer is responsible for all shipping charges, shipping insurance, and shipping materials when sending their stock/core heads to Frank Racing.
If you have any questions or would like to place an order, please contact me at [email protected] or 1-877-374-4364
Thanks, and I hope to help a few more cars sport Frank Racing equipment in the New Year!
Alex
Manager of Frank Racing Inc.
· Whippled Coyote
Milling the heads for compression increases combustion efficiency and yields about a 5-10% gain in power.
Alex,
With the combo I'll be running, what do you estimate my crank HP to be at, running the base tune ?
(exhaust will be JBA shorties, stock cats, JBA cat-back ... HHP high-flow cats eventually ...)
Discussion Starter · #17 ·
Due to the overwhelming number of orders and interest in our products, the FRI Head/Cam special is being extended indefinitely.
The pricing has worked out so well for the consumers and us that we see no reason to not let power like this be put into the hands of our customers at least for the immediate future.
I'm expecting to hold the pricing right where it is for at least another month, if not longer.
Give me a call at 1-877-374-4364 x 702 or drop an email to [email protected]
Thanks for your support, lets make this a FRI'd 2009 !
· Whippled Coyote
Alex, you have PMs :)
:mrgreen:
· No longer sporting dual R/T's!
What if I already have pretty much everything -except- the heads on my already Sidewindered 5.7?
How much for just the heads?
Mike
1 - 20 of 34 Posts
