1 - 6 of 6 Posts
Live To Ride/Drive To Live
My FM all of a sudden does not work. My guess is the FM plug came out behind the Nav system. AM works, CD changer works & NAV works.
How easy is it to pull off the center dash panel without breaking any clips to then pull the system out to make sure all is plugged in? Who has a step by step to pull the nav system? Thanks
The plastic panel is held in by several clips all the way around. The radio is held in by 4 Phillips head screws. Pretty straightforward.
Sent from my Pixel 5 using Tapatalk
Reactions: Brilliant R/T
You might not break any clips on the bezel, but the clips are secured onto the foam which may break... A while back someone designed clips to reinforce the foam
Sent from my VOG-L04 using Tapatalk
2007 Dodge Magnum Police Package
I thought most radios just have one antenna for both AM and FM. If the antenna wire is out I would expect both bands to only have static. Let us know what you find as I am curious.
Good luck with it and here’s hoping it is something simple to fix.
1 - 6 of 6 Posts
