1 - 2 of 2 Posts
Clever Disguise as a Responsible Adult
So, where the he11 is "pin #22" located?
Has anyone done the ESP mod on a late build-date Charger?
I cut into a blue/violet wire @ the top of the ABS connector and inserted a switch/relay, but the ESP still seems to be functioning.
There is another blue/violet wire on the bottom of the ABS connector, is that the infamous "pin #22"?
I get the ESP/BAS icon along with the "Mr. Squiggly" when I interupt the circuit but there seems to be no difference from the regular ESP off function.:sad:
15 Years of AWD fun
Try your ABS. If it doesn't work, then you have the right wire.
1 - 2 of 2 Posts
