1 - 7 of 7 Posts
Hello, my 2007 5.7 dodge charger hemi rt recently had overheated in California’s heat wave this past year and I finally got an engine but it is a 2016 year of the same engine. I was wondering if this engine swap will still go smooth considering it is the same except one is pre-eagle one is eagle. As well as I’d anyone knew any things that would be needed in this case to make it work.
· 2005rtmag
The 2016 engine has variable valve timing and I don't know how to get around that unless you can use the 2016 computer. But, I honestly don't know much about it. Is there a way to delete the variable valve timing?
· Red trucker
So a 2016 year of "the same engine" is not the same engine; the only thing they share is displacement....maybe starters and oil pans. Two very different engines.
Can it be done? Yes, and has been done. Smooth? No lol. Your PCM will absolutely not run that engine UNLESS.......you swap to a 32T tone ring and lock the VVT. Then you can just custom tune it, however you negate the whole advantage of using a VVT engine; then it's just easier & cheaper to cam it or cam it with better heads and you'll make the same power or better with less hassle.
The normal method is to get a 2009-10 PCM (newer 08-10 CAN style, but still within the same basic platform) with harness alterations. You'll need the front accessories, etc from an 09-10 5.7 becaus ethey changed in 2011, plus the 2016 engine doesn't have a PS pump (which you will need and your stocker won't work).
See, I more got this engine because I was able to get it for 1500 which saved me so much more money so I could afford to get the labor done properly. I don’t care about power right now, just so long as I’m not putting in like a 2.7 or something, I was just trying to match the power as best I could for the price. So if I were to take it to my mechanic, would you say I’d only need to purchase a 32 tone ring, the front accessories from an 09-10, and ps pump? I would get an 06-10 since they are almost the same model, but the cheapest I could find a used one was 3000. This is more just trying to get this car running again till I can fully fix it up in the future. Any other tips or advice if that changes anything?
Also
Also, would the PCM from my old engine work if I keep it in there? I know I’ve seen people do it and then tune it but I know i haven’t done it before so while I’m asking about the other things.
· stay modded, my friend...
If you still live in California, you will have a hard time getting it smogged. Even if you can lock cam and run your ECM a lack of EGR valve will fail the visual. Something to consider…
· Red trucker
Keep in mind, it isn't just "swapping the tone ring"; the crank has to be pulled completely OUT to do that.
Accessories from an 09-10 will have a PS pump already.
It isn't 06-10, it's 05-08. From 09 on it's the eagle engine.
If you're just "trying to get it running" then you bought the WRONG engine (no one researches anymore, they just see dollar signs lol). Find any 05-08 5.7 car engine and drop it in. Plug and play.
Go back and reread my original post very slowly.
1 - 7 of 7 Posts
