Ok so correct me if I’m wrong. You have two belts. one has nothing to do with the other.
Other then the lower pulley.
I used the pulley that came in the kit which was a double pulley
So each piece runs independently of each other
Which takes the other out of the equation. So if you have a problem with the serpentine belt what makes you think it’s the blower that is making it not run true?
They run independently of each other. I’m probably wrong like usual but please let us know what you do to fix it.
I’d look closer at the drive side and the lower pulley for this answer.
Yes, I have two belts that are mostly independent except they both run off the crank. The crank was pinned with a second pulley added to the crank to run the supercharger.
I didn't have any issues with the serpentine belt until a few months after I installed the supercharger. When it gets installed you reuse one of the oem idler pulleys that sits on the backside of the supercharger pulley bracket (#6 below).
While searching for that image I came across a thread where a guy is having a similar issue, it was on a jeep but all the same. In that thread someone posted the following (which appears to be from a repair type manual?):
“GROOVE JUMPING" (BELT DOES NOT MAINTAIN CORRECT POSITION ON PULLEY)
1. Belt tension either too high or too low (Replace automatic belt tensioner)
2. Belt routed incorrectly (Verify belt routing)
3. Incorrect belt (Replace belt)
4. Pulley(s) not within design tolerance (Replace pulley(s))
5. Foreign object(s) in grooves. (Remove foreign objects from grooves)
6. Pulley misalignment. (Check and replace)
7. Belt cord line is broken. (Replace belt)
Also in that thread the guy who posted similar issue eventually took it to the dealer that said it was his tensioner so they replaced that and the idler pulley for good measure. Just ordered replacements and going to give that a try.
