Below is a quote from fargo59's post on the new 5.7L Hemi code named 'Eagle'.
"tappets: i wouldn't normally cover this, but i actually made notes in class because of this. they have been revised for higher lift with proper MDS actuation. the stock cam lift now is approximately equal to that of the spartan/sparrow cams currently available. both of which are supposed to be the border line of MDS capacity. the new lifters do this constantly in factory form. further more, they are backwards compatible. they will drop right in to an older 5.7 (or any previous hemi built with MDS)"
Link
Has anyone thought about swapping out all of their current lifters to this newer version when doing a cam swap to a spartan or cam with similar lift? I would think this would give increased reliability as the spring will not be compressed as much.
Going further does anyone have any idea on what a full set would run (if you can even get one)? Would push rod lengths need to be altered as well? In that thread the push rods are also supposedly ~4mm longer. My guess is this is due to head design changes as the new lifter design I would think would decrease the required push rod length if anything.
Link
