In the ongoing saga of my Magnum...
So I recently swapped out the 5.7 on my RT for a new one. When I put on the intake manifold, it had blue gaskets already installed. The engine came with a set of gaskets with screens on the ports to prevent trash from getting into the engine. My mechanic friend said I don't have to install them because the intake manifold already had gaskets, and the screens would lower engine performance. Do I need to install the set of gaskets along with the ones that came already installed on the intake manifold?
Everything ran great for two weeks. But now, whenever I stop, the car would sputter and the check oil light would come on. This only happens after the car has warmed up to operating temperature and the idle dips below 1,000. I took it to a shop to have it diagnosed and they said it had low oil pressure, so I should change the oil pressure sensor, which was already brand new, or I may need a new oil pump, which is also a brand new Melling High-Performance pump. I opted first to switch the oil pressure sensor. I'll be doing that this weekend.
Something told me to check inside the intake manifold, so after removing the throttle body, I noticed a decent amount of oil pooling at the bottom. I know a little oil in there is typical, but this was maybe concerning. What's also concerning is that the oil was a dark brown, which is typical of used motor oil. However, the oil on the dipstick is still clear, like I just put it in. So, ultimately, I believe I may have received a faulty oil pump. I'm hoping it's just the OPS, or worst case scenario, I have to install the intake manifold gaskets along with the gaskets on the intake manifold. 🤞
