1 - 16 of 16 Posts
Hello all,
i m french and i ve a dodge magnum rt 2005.
i ve a matter.
My light engine is on.
I ve two codes diagnostic:(with my superchips)
- P0128 coolant temp thermostat
what is the problem?where is the part in the engine?
i can continouse to drive ?
- B1638
I ve not info with this.
everyone can me explain the codes?
I hope to have undrestant me.
Can you answere me with the simply word please.
A big thanks to ours help.
Have a good happy new year 2009
bye bye
Geoff
· LIVING A DREAM
The p0128 - do you have a 180* t-stat? If so it is possible that the cats and motor did not warm up fast enough. Very common with the lower temp t-stat. You might want to see if the car is getting hotter than normal or cooler than normal.The t-stat is located on the engine where the upper hose connects to the engine.
Not sure on B1638
· Threadkiller.........see?
Bon jour, Geoff,
The P0128 coolant temp code is okay to drive with. The engine didn't reach proper temperature when the computer expected it to. You probably need a new thermostat (located at the engine-end of the upper radiator hose).
B1638 code: I found this explanation at the following site http://www.obd-codes.com/trouble_codes/obd-ii-b-body-codes.php
B1638 Mirror Driver Right Short To Ground
Since our driver side mirrors are on the left, I'm not really sure what that means except that there is apparently a problem with one of your electric mirrors.
· LIVING A DREAM
Upon searching I found b1638 as this
Right high beam control circuit high
Is your right high beam light comming on , may be burt out
I searched the forums some more and found this regarding the B1638 code:
http://www.lxforums.com/board/showpost.php?p=714122&postcount=2
Code......06 Service Manual Page
B1634-LEFT HI BEAM CONTROL CIRCUIT
HIGH . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8L-11
B1638-RIGHT HI BEAM CONTROL
CIRCUIT HIGH. . . . . . . . . . . . . . . . . . . . . . . .8L-15
So looks like there could be a problem with one of the headlight high beams?
· What'd I miss?
bonjour Goeff. je va essayer de expliquer en francais.
P0128-THERMOSTAT RATIONALITY
si ton thermostat est original, va faloir le remplacer. il y a un link pour video pour changer le thermostat dans ce thread: http://www.lxforums.com/board/showthread.php?t=32989
B1638-RIGHT HI BEAM CONTROL CIRCUIT HIGH
le FCM (front control module) a detecter un short au voltage sur le circuit du phare (hi-beam) droit. je disconnect la battery pour 15 secondes pour effacer le code et verifier si il reviens.
Ok funky now can we get that in english. lol
· What'd I miss?
if you are using OE thermostat, you'll need to replace it. in this thread there is a link to a change out video: http://www.lxforums.com/board/showthread.php?t=32989
the FCM has detected a short to voltage in the right hi beam control circuit. i'd try disconnecting the battery for 15 seconds to erase the code and see if it returns.
howzat?
FNKY, you da man in at LEAST two languages - LOL!
Discussion Starter · #14 ·
lol Nobody ever asked if he spoke French. Being he's in Canada, it would seem logical. :spock: l
Hello , i live in europe and i speak french only, i m very dad with the englih.:doh:
I want to say a big thank for ours help (everybody):beerchug:
Discussion Starter · #15 ·
hi all
i have swap the part today.
i put one half hour because i m a newbie.
After i have drive with my familly during one hour.
I m very happy of ours help.:banana::rock::not_worth:beerchug::thumbs_u:
Have a good day.
Geoff
1 - 16 of 16 Posts
