1 - 1 of 1 Posts
· 2006 SRT8 Magnum opt I III Silver
just wanted to share my experience to help someone else, I have a 2006 Dodge Magnum SRT8 with 91000 miles, I have had a slight ticking noise at 28 to 30 miles an hour driving around town and could not figure out what is was, well today I pulled the driveshaft out and found that I had a tight middle u joint and it had weaked the rubber mounting of the carrier bearing, I replaced the carrier bearing and moved the u joint back and forth to try to move the lube around inside the caps, it did get better but still had a tight spot, I put it back together and the ticking sound is gone, the ujoint is not serviceable so I guess a driveshaft is what it will take to fix that.
1 - 1 of 1 Posts
