x2 for the Chargers. I would like to know if this is possible without replacing all the upper and lower dash pieces.Anyone tried or know of anyone who has attempted to swap in the 08 center console into a pre 08? Is it bolt in?
Where do you see 500? I'm seeing it for $952 there. And thats just for the Magnum. They dont have an option for 300 or Charger in the drop-down.The whole dash is only 500 from Moparpartz.com If I knew it would bolt right in I would order it. That way my mygig and 08 bezel would fit without mods and I could have the new console!
I'm basing this just by eye-balling but I believe the actual shifter is in the exact same place as the earlier years. Its just the console around it that's different. Maybe someone can contact PaP to confirm this. They've done the swap.i asked mr incredible about this not too long ago and he said it wont work.. u have to swap the dash the shifter and even then there are more technical issues with the switch of the shifter linkage... if Mr I says its not possible then i believe its not possible
the shifter is different, different style, different design, different canbus protocol, you need to change the dash, and the console, because the designs are different..I'm basing this just by eye-balling but I believe the actual shifter is in the exact same place as the earlier years. Its just the console around it that's different. Maybe someone can contact PaP to confirm this. They've done the swap.
I believe you're talking about 300s MrIncredible. I have a Charger; To your knowledge is this true with the Chargers as well? If so... to keep this as simple as possible, I'm thinking a nice loose cloth/leather base around the entire shifter (think Infiniti or come BMWs) would cover up all those incongruities nicely. Thoughts? Also, what type of prices have you seen for the dashes? I'm thinking I'd need Dash Panel, Glovebox Door, Panel over your knees (dunno what its called), Center console bezel, Center console storage box cover....the shifter is different, different style, different design, different canbus protocol, you need to change the dash, and the console, because the designs are different..
then you need to change the body harness and wiring because the connectors on the gear selector are different, the TCM is different, and the canbus is different..
regardless of whether it is in the same location or not, it is a different design and a different network
now I am sure you could swap the dash and the console, and keep your gear shifter, but then you need to fab up something to fill in the gap around it as the pre-2008 shifter is lower and more narrow..
the 2008 is taller by nearly 2 inches and wider by about 4..
I've taken the measurements, and checked into it when the 2008's first came out..
I even had a 2008 console I tried to mate up, and without switch a ton of parts and/or fabbing bunch of stuff to make old and new work, it wasn't worth the cost, time and effort to do it.. too much has changed..
