1 - 12 of 12 Posts
Has anyone used them ? A customer of mine stopped in and had them in his 5.7, I had never seen them before and they were really an interesting design.
Any results with them ? I replaced them with 2314 NGK's and sent him on his way.
Is the Brisk a good plug ? For $15 a pop they better be...
· 15 Years of AWD fun
At $15 a pop they should never have to be replaced.
· T.G.I.F.
· 2010 Challenger R/T DWB sig 4 mods list
What I have never understood was the logic behind the basic design of the standard copper plug. Dont we want to spark the fuel on top of the piston and push it down? Why then do we spark the side of the block? Would it be logical to have the spark facing the top of the piston, not the block? Are we pushing at the block or the piston? Why make the fuel burn in an L shape when you can go in an O shape pushing directly down.
What am I missing? Why do we put the spark against the block instid of pointing it at the piston? Do you put your hand in front of a flash light when you are shining it at something?
· Mopar or No Car
Explosion
The spark ignites the fuel which then explodes in every direction including sides and down so the location of the spark does not matter.
they will work. seemed to do ok in this car for the long term use. but looks like some issue did arise. some of the plugs where broken. ill have to get some pics taken. it was not pretty. concerned me where that big piece went to also.
steve
1 - 12 of 12 Posts
