1 - 6 of 6 Posts
TSB #: 05-006-06
Date: August 2, 2006
Subject: Front And/Or Rear Brake Rotors Grooved/Scored
Models: 2005 - 2006 (LX) SRT8 Charger, SRT8 Magnum, SRT8 300C
Symptom/Condition: Front and/or rear brake rotors may appear grooved or scored prematurely.
Diagnosis: Inspect the brake rotors. If the rotors show premature grooving or scoring, perform the Repair Procedure.
Repair Procedure: Using the procedures outlined in TechCONNECT: SERVICE INFO tab /5 - Brakes/Hydraulic replace the front and rear brake rotors with the slotted rotors listed in the Parts Required section. Inspect the brake pads and replace the pads as necessary.
NOTE: If premature grooving or scoring is present on any rotor, slotted rotors must be installed in the front and rear.
Policy: Reimbursable within the provisions of the warranty.
PDF file of bulletin: #05-006-06
--RS--
05 Magnum RT and 10 Challenger
This looks to be about rotors only not pads. If you are making a ton of dust, but have no grooving, looks like you are SOL.
I'm gonna get the Zechhausen C-Tec pads when they are in later this month and try that.
Well,after the trip home I got both.My rotors look like hell and the dust is amazing.So I'll be doing the TSB and the pads as well!
1 - 6 of 6 Posts
