Try giving it a shot of WD-40. Usually works for squeaks on moving parts.
I did that already....come on now.Northern Rider said:Try giving it a shot of WD-40. Usually works for squeaks on moving parts.
trying tonight. Results to follow.fnkychkn said:Apply lithium grease to the spring located at the brake pedal pivot point. The grease should be applied to all surfaces of the spring and at each of the hard contact points to the pedal assembly. Exercise the pedal to make sure the noise is eliminated
KFC either you have the tech manual there at home or you have just been reading tech manuals too long. :mrgreen:fnkychkn said:Apply lithium grease to the spring located at the brake pedal pivot point. The grease should be applied to all surfaces of the spring and at each of the hard contact points to the pedal assembly. Exercise the pedal to make sure the noise is eliminated
you're right Old Navy, i do have access to online FSM, as well as the most up to date TSBs and tech tips. you're also right about me reading a lot of technical manuals. :lol:Old Navy said:KFC either you have the tech manual there at home or you have just been reading tech manuals too long. :mrgreen:
lol 8)Hardrock said:Hey ghb2, I get the "pop" sometimes when applying the brake. Looks like
it's time for a TSB to be issued for it which would state "Borrow SoCal's
tube of lithium grease and shut up".
Took years of practice for me to quit the tech speak.fnkychkn said:you're right Old Navy, i do have access to online FSM, as well as the most up to date TSBs and tech tips. you're also right about me reading a lot of technical manuals. :lol:
