1 - 8 of 8 Posts
The Maine Magnum
I have had my blastin bob's 7 db kit on for about two months now. my check engine light came on on monday and I am going into the dealership on Monday. Is there anyway the light could be on beacuse of the pipes?
What'd I miss?
if the pipes are only cat-back, not likely. if they include high flow cats, definite possibility.
AG Strek
I have had the 11's on as well since April I think, not a single issue..all they do is replace the stock resonators...nothing more
The member formerly known as Jleilich
Get your self a scanner, or check the CEL code and it will tell you if it is exhaust related or not.
G
All you have done in effect is removed the resonators, it cannot throw any codes.
Mine have been on for about 4 or 5 months, never an issue.
2006 Mag SRT Owner
If you have an EVIC, there is a method in the knowledge base about how to show the codes.
Maybe someone will post it here. I think its turn the ignition ON then to ACC then to ON then to ACC, then to ON and they will display one at a time in where the odometer usually is.
After its finished or if there are no codes, it will display a ------ dOne
Am I close?
Thanks,
Don
1 - 8 of 8 Posts
