I was having this issue and through a lot of experimentation it has gone away. BCR has said it is most likely an issue with the lower mount bushing and are working on a fix as far as I know but by lengthening the shock a little and reducing the preload on the spring, the squeaking has gone away. Just figured I would share in case anyone else wants to try. I also ran into an issue where the factory torque specs for the lower shock mount wasn't enough. I was getting quite a bit of rattling which I had attributed to the shock being lengthened but after torquing that bolt down to 90-100 ft/lbs instead of the factory 53 it immediately went away.
Just a few things for people to give a shot, you might get lucky like I did.
Edit: Turned out to only be a temporary fix. Squeaking is back as of this morning.
