The pre-load should be set from the factory, but this is easy to check and set yourself as well, we can walk you through that at the time of your purchase if you'd like!Do these coilovers come with PreLoad adjusted on the front springs?
For a 2006 Charger SRT8.....What is the default spring rate supplied?
