Your not trying hard enough fella. You want too much hand holding silver platter treatment.
Go to
THIS FORUM THREAD and carefully read the 1st post and heed every word. Especially the backup instructions. Some of the following early threads are good too.
Backups are not something one can use to overwrite, they are for comparisons. Every time you make one it adds it to the end of the last one.
Bone up on norepad++ and the compare plug in.
This is a partial copy from one of my backups. Chassis Type is listed in Vehicle Config 3:
Good Luck
Vehicle Config 3:
Police Lighting Feature: Not set
Power Lift Gate Present: Not set
Power Right Sliding Door Present: Not set
Power Left Sliding Door Present: Not set
RKE System Present: Set
Sunshade Present: Not set
T-Case Type: Not present
Fuel Capacity: 73 Liters
Wheel Base: Not defined
FOBIK Safe Enable: Set
ELV Present: Not set
Window Express Feature Configuration: Front windows express only
Adjustable Pedal Feature Present (non-Memory): Not set
Auto Headlamp Feature Present: Set
Door Alert Feature Present: Not set
Two Fuel Sending Units Present: Set
Vehicle is an SRT: Set
Disable Display of Radio Clock: Not set
Chassis Type: Type 23
Display Outside Temperature Present: Set
HVAC Configuration: Dual Zone ATC
Vehicle Brand: Dodge
Display Compass Heading Present: Set
Interior EC Mirror Present: Set
ESCL system present: Not set
High Intensity Discharge Head Lamps: Set
Secondary Lock Present: Not set
Liftgate/Trunk Type: Trunk
Collision Mitigation System present: Not set
Forward Collision Warning present: Not set
Base TPM system present: Not set
Premium TPM system present: Set
Paddle Shift Feature Present: Not set
Sport Mode Present: Set
