1 - 13 of 13 Posts
will i need to run spacers on my 07 rt?
what size tires should i buy (no tires on wheels)?
is the weight of the 20 really gonna mess up how my car accelerates and generally feel like it weighs more than my stock 18s?
do i have to run the tpm system? if i dont how do i turn off the light???
any other comments you add?
i am getting them for a steal at 350 for the set of 4, no tires or tpm's, the wheels are rated 7 out of 10 though.....
They are great. You can go with 3 different tires up front. Yes you will need spacers. for 275-40-20 you will need a 1/4 inch spacer. In the rear you dont need anything. It is good to run the TPMS. I took the ones out of my 18's and put them on the 20's. You wont notice a difference in acceleration. you will have less sidewall so you will be able to break loose depending on the size you go with.
· 07 Charger RT R&T
Sensors will be fine. If you don't want them installed, build a torpedo out of schedule 120 pvc, put the sensors in it, seal it, put a valve on it and pressure it to about 40#. Throw it in the trunk next to your spare and no light.
No kidding? HA! That's great.
It'll read them from back there?
· 07 Charger RT R&T
I take no credit for the idea. I forget who on here had this chicken but it is a great idea. As long as they are near the car you should be fine. Awesome plan.
· Got me a Lime, now wheres the Patron!
Im running the factory 245/45/20 up front, and 255/45/20 in the rear.........I like the way it grips and feels alot........I have no spacers on mine.....I chose to shave the control arm and been good ever since.......7 months now doing over 100mph everyday, no issues at all
Discussion Starter · #11 ·
does anyone have pics to show how much i need to grind down???? and does bt still make the spacers if i wanna go that route???
and whats wrong with the stock lugs???
· Baba Booey
The stock lugs have a crappy tin cap on them that likes to deform, and occasionally come off.
AC
1 - 13 of 13 Posts
