I have a built 6.1L HEMI Forged 2618 Drop In Pistons and Rods Power Package MAHLE Modern Muscle 2618 Piston
2618 material Factory weight
Top ring moved down
Accumulator groove between first and second ring
Napier oil control second ring
Steel top ring
Coated skirts
Coated ring lands
Comp ratio 9.7 to 10.0 depending on gasket selection
Molnar Rods
ARP Rod Bolts
Coated bearing option for high HP builds.this is still a standard bore engine.new mopar roller lifters king bearings,roller timing change,new mopar oil pump,hhp stage 2 blower comp cam,hhp valve springs and retainers,bowl work plus valve job done to the heads.arp head bolts,new mopar main bolts, Mopar OEM 6.1L Head Gasket Set - 5037592AC for nitrous or boost.the engine is still in car to hear running or video to be sent.this combo has less than 5000 miles that was ran with a procharger (that's also for sale).made great power and was tuned by Erik at BFNY IN OHIO.LOOKING for an usable core in exchange.this IS LONG BLOCK ONLY MINUS INTAKE AND HEADERS AND ACCESSORIES. I will have more pics up later.thank you
