I am starting this thread because as soon as someone talks about a swap on an LX the common answer is: "trade it in" or "get a hemi". I find this advice weird because some people here have paid off their cars and do not want to go further in debt or upside down their loans, some have modded it beyond the point of return and love their cars as they are and want to keep them for a long time. Some will also tell you that this is an expenive endevour (false).
I have succesfully completed mine.
If you are stuck with a 42rle transmission and you long for that solid NAG1 because there is no way you are selling a car or are planning a sweet v8 upgrade because your cheap v6 has been paid for here is what you will need. I suggest browsing junk yards for various parts at www.car-part.com
IF PURCHASING FROM JUNK YARDS ALWAYS ask them to cut with a wire harness!!!! Example: if you need the TCM tell them to leave wire with it.
REQUIREMENTS!!! READ THIS BEFORE DOING ANYTHING
Before doing this you must have an LX equipped with ABS, if you do not have ABS, limp mode forever. In that case you need the ABS assembly, the abs pump abs module and some wiring to wrie it in and get it authorized in your FCM (this could prove to be a challenge and will require patience to complete but the price of the parts is relatively cheap at junkyards I saw the whole assembly for like 100$, Jon (Nyinstaller) will be able to probably authorize it in the FCM)
If you are the type to read a wiring diagram (you better if you are doing this yourself) you will notice that all 4 speeds are missing a power source for the tcm whereas 5 speeds have a fuse in the rear for the TCM, the solution I came up with is to make a relay with a 10 amp fuse (unsure of the amperage I used, damn you memory) and wire it to the ignition so it has constant power and does not lose power during crank. You can make a zener diode and run it from the back to the front if you are a perfectionist but this method will work just fine.
Electronics, I will start by this because these are the most complex parts of this whole swap:
You will absolutely need a PREDATOR/INTUNE/TRINITY this is because a 4 speed has a 3.64 gear ratio and a 5 speed has a 2.82 gear ratio. These little beauties have the ability to match up your gear ratios, if you do not match these up you will be in limp mode forever.
You will need the TCM (average junkyard price 70$) part # 04692392AB, you do not need to do any reprogramming on this because the predator will rewrite the gear ratio to 3.64. ALSO ASK THEM TO LEAVE THE WIRE HARNESS IN AND CUT THE WIRE, you will have to wire up this part to the transmission.
You will also need the POWER TRAIN CONTROL MODULE (70$ from junk yard) part #04606838AB, (junkyards will call this the ENGINE CONTROL UNIT, or ECU, or ECM) but as long as it belonged to a v6 with a 5 speed automatic you should be fine because this needs reprogramming as the PCM has to match up and see your VIN for the car to start. If you do not reprogram, your car will start and shut off after 30 seconds. Jon at AMP (After Hours Mopar Performance) reprograms these beauties for about 150$ a pop you just send him your 4 speed PCM and he rewrites the software and proper VIN in it. I was lucky enough to know a chrysler tech that brought the starscan over and did it at my place but expect the dealer to charge you through the butt (more than jon from AMP).
You need to send your ORIGINAL FRONT CONTROL MODULE (the computer that is plugged into the front fusebox) to Jon if you want the shifter module authorized and that autostick is reflected in your cluster (without this, the car will shift through the gears but you will not have the ability to use autostick and if you try to use it without proper authorizations your transmission will act funky, so beware! (this is approx 150- 175 to do)
Mechanical parts:
THE TRANSMISSION NAG1 (DUH) must be from a V6, bellhousings are not the same from V8 to V6 (approx 400$ for a low mileage one) you must ask them to leave atleast 12 inches of wire, this wire will connect to the TCM. Please note that you will need to connect this part to the TCM. Also ask them to leave the shiftcable on as well as the flywheel, and also the OIL FILLER TUBE if you are dumb like me you will be chasing down hard to find parts later down the road and waiting to finish your stuff.
IF YOU FORGOT TO ASK FOR THE ATTACHED FLYWHEEL SHIFT CABLE AND OIL FILLER TUBE or for some reason the junkyard only had the transmission you will have to chase down these crucial parts.
Your local stealership has you covered or moparoverstock.com also
Oil filler tube(9$), you will need parts the oil filler tube PART # 04591880AE ; 04591880AB; 04591880AC; 04591880AD (these will vary across the world and where you purchase them) but here is the link for the correct part
http://www.moparpartsoverstock.com/...ansmission-Oil-Filler/6945555/04591880AE.html
AND
A mounting grommet for the oil filler tube(3$)
04810021AB ; 04591879AC; 04800252AA; 04810021; 05189087AA; 68810021 (possible part #)
http://www.moparpartsoverstock.com/...e--Oil-Filler-Tube-To/6658714/04810021AB.html
FLYWHEEL/FLEXPLATE(40$)
04752600AA
http://www.moparpartsoverstock.com/...orque-Converter-Drive/6643067/04752600AA.html
CABLE GEAR SELECTOR (SHIFT CABLE) 79$ (ask for this in the junkyard they will usually want like 10$ for it)
04578073AD ; 04578073AB; 04578073AC
http://www.moparpartsoverstock.com/p/__/CABLE-Gear-Selector/6640272/04578073AD.html
SHIFT CABLE MOUNTING BRACKET (1$)
04578071AA
http://www.moparpartsoverstock.com/p/__/BRACKET-Cable-Mounting/6662179/04578071AA.html
AUTO STICK FLOOR SHIFTER ASSEMBLY buy at junk yard (approx 50$)
DRIVESHAFT FROM 5 SPEED (100$$) buy at junkyard
TRANSMISSION MOUNT 30$ at junkyard (make sure it is from a 5 speed) (I had to drill through my frame to get this to fit on my car as it would absolutely not fit in any way I tried but on some LX cars it will fit no problem)
TRANSMISSION COOLER LINES (approx 200$ at stealership) This to me is optional, the 4 speed cooler lines do not align, but I just bent them and used tightly clamped rubber hoses to reach the tranny, and I coupled that with a transmission cooler from B&M, it should hold up just fine, it is not a high pressure point. Just keep an eye on it!
7 liters of ATF +4 TRANNY FLUID (prices will vary use dipstick to gage how much fluid you'll need, remember your torque converter will be empty too, so you may need the whole 7 liters)
I recommend buying a transmission dipstick, changing the pan gasket and tranny filter, and also every single o-ring! Not necessary but as long as you are under the car, might as well do it... o-rings have been known to leak or let water in and this tranny does not play well with water mixed with transmission fluid....
as for the cost assuming you already have a predator.
expect to pay from 700 to 1000$ in parts (with shipping)
finding a fair mechanic to do the wiring and install 500$ approx
Reprogramming of the pcm and fcm approx 300- 340 by jon.
my total cost was 1100$ with labor and programming.
You have your parts. Now you have to find someone to empty out your transmission, do your wiring and install the new transmission and reprogram the PCM/FCM and you are out the door!
This transmission is compatible with many mods
the Tranzformer
Paddle shifters
Blue top solenoids
etcetc
It is a lot more solid and does not tend to overheat as much as the 42rle which is practical for supercharger applications or straight up V8 swaps the bellhousing can come undone and you can use the V8 bellhousing.
Credits:
Much of the merit goes to Jon at AMP for helping me and also MADDOG from 300cforums!!
Thanks guys you sure made this experience easier and I hope this thread will make it easier on some other modders!
Enjoy!
(this may seem like a lot of trouble but it is not that bad especially if the car is all yours and you plan on keeping it and modding out in a beast of a ride)
Mechanical parts:
AND
04752600AA
04578071AA
the Tranzformer
Paddle shifters
Blue top solenoids
etcetc
Credits:
Enjoy!
