41 - 58 of 58 Posts
· Im Back in Black!!!!
Actually that's about right. At a little over 800 HP I was running 10.8's with my last build. The calcs for this don't take DA into account.
BTW I've got a number of calculators on my site if anyone is interested. Just click here... Wink's Hobby - Calculators
wink
So when I run 10.8s i'll be at 800 hp?? i'll be more around 600 rwhp...im at sea level...so HP is different...I think you figured that out on your previous posy i see...
· Four hundred twenty six reasons
4600 lbs .3 tenths away for high 10s...i have no were near 800 hp nor 600 rwhp...that i know of car has never been on a dyno.
You may be close to 600 with the giggle juice.... I'm hoping to crack into the tens with a 150 shot ,
Possible yeah... hit 11.3 on just a 100 shot seeing what the lakewood 70/30s do and the Ding VB i just had installed does before i up the shot... but in all reality im still a all stock long block..stock manifolds and cats....lol
Reactions: ronan978
· Beast Pilot
No, and sorry for the confusion. I was trying to make a point about trusting calculators. They're handy, but not gospel. The calculator said I was making 800 HP, but I already know I wasn't. I was around 640 HP running 10.8's.
This is the specific dyno pull I was talking about. Using the SAE correction factor. What most people use to have a same frame of reference. It says 801 / 736.
This is the same pull without a correction factor. In reality I was making 641 / 589.
Big difference because up here I'm have about an 18% power loss just from altitude. Add in the weather and it's an even bigger loss.
Anyways I'd say you'd need to be around 640-650ish to run a 10.8 in Lakewood. Might even be quicker as you're lighter than me. If you were at 800 HP I'd suspect you'd be running 9's.
wink
· Beast Pilot
Hmmm... The calculator says 652. I'd have thought that would get you there. But I also figured you're lighter than 4600 lbs. Are you spinning or hooking solid? What does your 60' look like? Again, going by the calculators, looks like you're maybe 70 HP shy. Your call but a larger shot shot could get you there. Just not sure I'd go bigger on a stock bottom end. Getting away with something and being safe are different animals.
wink
wink
60fts are 1.5s car hooks... and that was just a 100 shot the 6.1s will take a 150 shot no problems... car is tuned also...and yes it weighs 4600 lbs im 260 lbs...lol believe me its never been on a dyno i really have no idea of HP i just think it moves pretty decent for what it is.. and if i can hit 10.8s i would be very happy for what i have invested into the car..
Reactions: ronan978
· Beast Pilot
Damn! By all rights you should already be there. I figured you were gonna say 1.6-1.7 and spinning. If I run slower than a 1.5, I run a low 11, otherwise it's always a 10. Guess you'll have to up your shot, and pull some timing. I'm just scared of that stuff. Seen several have malfunctions, one staging right in front of me. Boom! About an inch or so of daylight between the hood and fender. But I see many others have no issues.
wink
wink
Nitrous is instant torque so it comes off the line hard then levels off so thats where i say i lost a little during the run..bottle looses pressure...plus i had flare between shifts on bigger shots so i just had a troy ding VB installed to help that out so i can up the shot...i think my goal is attainable..juts some fine tuning might even need a little weight reduction..IE front and rear seats out....i really do want to do that but a tenth is a tenth...LOL..
Welp, this thread's about to get locked.
Sent from my moto z4 using Tapatalk
Why , what'd I miss!!!
Reactions: Yar
Reactions: SCOTT57RT
41 - 58 of 58 Posts
